Monitor Wobble
petercasino
212CR
I've got a monitor that wobbles when it's in a cocktail cab but when I place it outside the cab (still powered and fed from the cabinet), the picture is perfect. Has anyone come across this before and solved it? The earth connections are all good. I've tried removing the degaussing circuit and flipping the screen around but nothing changes the wobble. I'm assuming it's interference from the power transformer (Atari power brick). The monitor itself is running off 240V rather than 120V could this be contributing to the problem?
Thanks,
Mike
andrew96
899CR
yeah its some changing magnetic field which most likely from a transformer, If you can find the source you can always place some MU-metal between the source and the monitor
andrewsm
485CR
Do it with power off and unplugged. try just removing securing screws and moving it a little clockwise or anticlockwise. You might find a position that helps. Power it up each time though and if you feel safe enough you can try it with power on, just watch live terminals etc obviously.
