Monitors dead but games are running?
IndyJones
"Partial to Tooty Frooties"
375CR
Ok, after fixing Vendetta I want to fix 2 more niggling cab problems, I put my Beast Busters 2 & SCI into storage, a bit damp, almost too scared to say but it was a container
When they went in about 2 years ago they ran fine, now both monitors are dead but the games are running in the background.
Am I to just assume the monitors are dead & need repairing by an expert or is there any simple things I can check on myself? Sadly they would need to be simple things as my tech knowledge is growing but still only on a grade "keep trying"
Any simple pointers would be greatly appreciated to keep repair costs down.
andrew96
899CR
Monitors just don't like dampness, might be as simple as a rusty fuse or fuseholder not making good contact, if your unlucky it might be the flyback or related high voltage side that's bit the dust,
andrew96
899CR
This was the fuses on a old Hantarex MTC900 (the older one, not the E version)
they was all faulty and I had to replace them before i could even get anything from the psu! this had been stored for years in a bad environment I am sure! but got the monitor all working in the end!
andrew96
899CR
yep!! the fusewire even looks intact inside the glass fuses, but that too was eaten away at the ends! these were the worst corrosion affected fuses I had seen!
IndyJones
375CR
Thanks for that Andrew
I will get the back off & locate the fuses, give them the once over, assuming thats not the case, if I strip off the chassis is the "flyback or related high voltage side" on that section & do you know anyone who repairs them?
Someone suggested try the local tv repair shop but I did some research & someone told me they are a bit dodgy, do substandard work so things go wrong & also a bit lightfingered as well, the last people I want around.
andrew96
899CR
Its difficult, local is a good way to go, or someone that has a tube you can send the chassis to, but with so many different chassis about its impossible for someone to have all the tubes!
I did look about for a courier but it didn't work out cheep to transport monitors and they could not guarantee necking on the way! so i gave up trying to offer a cheap way of getting monitors repaired even though i used to do them for a living back in the 1990's
what chassis are they?
IndyJones
375CR
Its a bit more complex than I'd hoped then, I was hoping its possible to send off the chassis where the problems would maybe be obvious, I never realised you needed the tube as well, like I said I'm a bit green to all of this stuff.
I have pulled the back off sci but the monitor back is protected my a metal casing, I will unscrew it & find some details later, model no etc.
Thanks for the help.
bbz149
26 (100%)
1,608CR
Does the Chassis have a little TH1 transformer on it? I found one of mine had the little thin wire to one of the top posts rusted away as the wire is very thin! I now dip them in that Red transformer insulation paint stuff and let the dry
