Moon Cresta eproms
dulstone
22CR
I've picked up a moon cresta board that has a wiring adapter attached
to enable it to plug into a taito space invaders cocktail wiring loom.
The board almost works in that I have a picture, character set and it
runs the initial test, but reports a bad rom, and then reboots. Can
anyone help me identify which mooncresta rom set from the 5 or so
available from mame I need to use, and which image relates to which
EPROM on the board.
The board is basically a 2 layer board (I can't spot any
manufacturing label) with 4 EPROMs on the top board at locations
marked 7M,7K,7H,7F (only the one in 7M has a label reading 4A); 4
further unlabelled EPROMs on a daughterboard plugged into the top
board in locations 8J, 8F, and 4 further EPROMs on another
daughterboard plugged onto the bottom of the lower main board - these
4 have labels still intact saying 1B, 2B, 3B and 4B.
If I can identify the correct rom set then I can then test and
replace the bad EPROM.
Can anyone point me in the right direction ?
Rob.
G
Guests
Guest
Read the other program roms to work out what you have - Cheers, Col
favouredson
Super Star
1,260CR
If you have the ability to test/burn a replacement then surely you can
read the program ROMs and RomIdent them to find which set you have???
Or, if they don't RomIdent, check the CRCs against those in MAME.
There appear to be three bootleg sets in MAME so it shouldn't take long.
favouredson2006-04-24 23:06:40
