More Naomi Problems :(
trev1976
171CR
Having problems with my naomi running at 15khz (dip 1 on)
Its hard to see on the video but while it's loading and in game it seems to be getting some sort of power
spike which comes with a loud buzzing noise and a purple and green screen , then it goes away and then comes back ?
I've checked all voltages
Sun psu
5.06
- 3.33
- 12.16
Supergun
5.04
Also CVS2 comes up with the message that the I/O does not have
enough switches or functions .
I do have a Capcom 6 button wiring harness connected too ?
Also i managed to get CVS Pro to work but the controls were weirding out ? ive tried the controls on my CPS2 stuff and they work perfectly.
Pretty confused
https://www.youtube.com/watch?v=6lWeoPmEdXo
trev1976
171CR
Ok tested on 31khz , no weird screen or buzzing but the controls still do not work properly , ive tried 2 different joysticks too and while one is better than the other i still cant get all the controls to work , maybe its supergun related but its always been fine with my other PCBs
Ill have to try it in my aero at 15khz and see if that works but id really like to get these controls sorted so i can play on my 31khz monitor in a seperate room , are there any other options for getting controls sorted on these boards ?
mecha
10CR
might be a setting in the NAOMI test mode, I'm pretty fuzzy on their operation right now but there might be a JVS option you have to turn off.
I really miss working with these.
trev1976
171CR
Ok thanks , I'll have to try it in my cab at some point as to navigate the test menu you need to use the service button and my supergun dosnt have one
