Mr Do test ROM
philmurr
48 (100%)
2,374CR
I've had someone's Mr Do board to repair for far too long now, so to make life easier I've modified the other test ROMs I've done to work with Mr Do.
It tests the programme RAM, background and foreground RAM, then sits at a screen showing the status of the inputs and DIP switches in real time. Has been tested in Mame and on an original Universal board.
The test ROM has shown the foreground RAM being faulty on the board I have to repair so now need to spend some time working with the schematics
Input and DIP switch testing screen is below
The test ROM code can be downloaded from the link below. Burn the code to a 2764 and replace the EPROM at a4 (a4-01.bin in Mame)
https://www.ukvac.com/forum/data/uploads/183/mrdotestrom.zip
philmurr
48 (100%)
2,374CR
virtvic said:
Is it daft to ask if it will work with similar Universal hardware games (or be modified to do so) ???
It should be fairly easy to adapt, I'll just need to change the addresses it checks. Any particular game?
