MS-2932 Vertical collapse
Vamino
Insert coin(s)
2,700CR
I had a monitor fail with vertical collapse earlier in the year, so I used a spare chassis I had and put this one aside. Shane offered to recap the chassis and I also asked him to fit a vertical IC at the same time.
I've just tested the chassis and it still has vertical collapse so the issue must lay elsewhere.
I also tried 2 remote boards just to rule that out.
Is there anywhere else we should be looking?
Any common issues with resisitors failing or cold solder joints which would cause this issue?
Thanks for any help.
M K L
1,158CR
The vertical IC is supplied by two voltages, 12V on pin 1 and 24V on pin 8. 24V comes directly from the power supply and 12V comes from voltage regulator U951 which shouldn't be bad as it also supplies the horizontal drive transformer and the horizontal deflection is working. 12V goes to pin 1 of the vertical IC through R425 which is a fusible resistor. Check if you have 12V at both sides of the resistor or just check if it's open.
Vamino
Insert coin(s)
2,700CR
Thanks guys.
I've just measured the resistor at R425 in circuit, it looks like it's measuring 098 ohms, I also measured the same resisitor on another (untested) chassis and it measures the same.
I'll check for 12v either side of the resistor later, I may just order a couple more IC's as well.
