Ms Pac again
maskeddev
88CR
Yo,
So this Ms Pac kept restarting. RGP tells me to clean the edge connectors so I've done that.
That has reduced the restarts a lot. I left the machine on for an hour. It restarted twice, once after about 5 minutes, another after about 10 minutes.
The edge connector is getting very hot... is this ok? I don't normally feel edge connectors.
Thanks,
Aaron.
big10p
Coins detected in pocket!
6,091CR
I'm not familiar with this cab, but I doubt the edge connector should get that hot. I assume you've checked all voltages?
big10p
6,091CR
For me, step 1 would be to look up the Ms Pac-Man pinout, and use it to check voltages at the edge connector, with the board plugged in and running.
Since the edge connector is getting that hot, I'm thinking maybe something on the PCB is overheating, causing a reset.
big10p2017-06-27 12:47:48
maskeddev
88CR
maskeddev
88CR
I got the manual here. I have a multimeter too but don't really know how to use it or what values I should be checking on this
Just had the machine on for half hour. It never reset. The edge connector at the power end is now red hot though.
big10p
6,091CR
Yeah, that doesn't sound right, to me. See my post above for step 1. Since you have the manual, the pinout should be in there. There are plenty of tuts and vids around on how to use a meter to check voltages, but if you have a specific question, just ask here.
