Ms8 26su
8,284CR
Lovely raster
Lovely neck glow
Can’t get image ?
I have tried 2 jamma looms and 2
Psu
1 happ psu meters the 5v
On both ..
Either it don’t like the 19 in 1
pandoras I’m using to test .
Also a Puznic jamma board .
No image .
I have tried connecting the H sync & v sync ..
Even though I know it wasn’t going to bring and image up on screen ..
Screen does sync when power is applied to my video source .
Is this duel res ?
If set to 24 kHz would I
Get no RGB?
Poss main cap on kneck pcb ?
8,284CR
Check for 120VDC on one of the big resistors (R305 or 315 or 325) on the neckboard. If there's no voltage, R570 (near the flyback) is open.
This is what I got on r570
Which is slowly tricking down
K ohms reads OL open circuit ..
So I change this and caps in the circuit which most likely caused the issue ?
4.7 ohm fusesble
Or fire resistant ?
Thanks 👍
8,284CR
If you had checked voltage (which is now understood you hate to do LOL) you would know.
Nah love
It 🥰I’m thinking of putting it back on before I take resistor out ..
More testing the better 😁👍
Will show you the voltage I get on them RGB amp resistor legs ..
Bare with I got 2 kids 🤣 Not sure I can get back at it tonight though ,
🤞 hoping for 0 volts ..
But not a faulty flyback just bad dry caps
