Ms8 26su
8,284CR
Similair little resister infront of the zenner zd431
Reads 12.44 K ohms. ?
That resister Going out of range ?
Can I read q402 and q401
In circuit ?
Any schimatic for this chasis ?
I cannot see a ident for this resister in the silk screen
8,284CR
Base to emitter voltage drop ..
Should be 0.5-0.7v
Is that reading of 674
0.674 v ?
I like this multi meter
That transistor q402 passed both ways round , all tests
It’s good .
Thermal paste applied it’s back on the chassis
8,284CR
Good voltage drop
No shorts ?
Isn’t that supposed to be 50 v ?
Not according to the other chassis
Right check r433 on the good chasiss
It was same 2.2kohm
8,284CR
Check little tantalum
Tantilum
12.38on good chasiss
8.61 on bad chasiss ?
33 percent drop
D432 good chasiss 14.32
Bad chasiss. 16.40
C433 Good chasis 12.50 kh
Bad chassis 14.29
R436 good chassis 9,8
Bad. Chassis 8.9
C437 good chasiss 8.53
Bad chassi 4.20
