Ms9-29
robotech
823CR
Hi
I have a couple of ms9 29 chassis in my spares pile I have re capped both of them but still get no neck glow or static on the front of the tube I've been reading about these and the protection circuits so that could explain the kind of power up noise they both make on the test bench
Does anyone have a link to a diagrame for these chassis or know of any common problems that they suffer from
Basic checks ect
Thanks robotech2021-08-14 00:02:51
8,292CR
i posted a link here the other day on this
from arcade projects that explains the repair..
i will try to find it for you
in mean time
power on you hear HV and then lose HV right away you are in protection circuit. If you "start" and hear click click click. You are in protection as well from current draw.
Retroman8392021-08-15 16:15:21
Vamino
Insert coin(s)
2,700CR
I've also got a couple of MS9 chassis in the loft with the same issue.
I had one recapped and it's still dead but didn't take it any further as I didn't need a working one right now.
Looks like replacing the mosfet is the next point of call going by the info in the link above?
Vamino
Insert coin(s)
2,700CR
Just bought some mosfets/transistors off Aliexpress so hopefully they sort the issue. If not, then I guess it's onto the next barrel of the shotgunning process.
Vamino2021-08-17 20:47:17
Vamino
Insert coin(s)
2,700CR
Ah OK, thanks for the info mate.
Will see how it goes when the transistors arrive, pretty sure I have some vertical IC's too, I may have even fitted one when the one was recapped...I can't remember as it's been a while since I tinkered with them!
Vamino
Insert coin(s)
2,700CR
I dug out some bits to check over at the weekend.
To help with testing I also pulled out 2 x untested MS9 monitors from a couple of my project Astro City cabs.
First we put one tube through a light cleaning cycle on a rejuvinator, 2 guns were showing as bad and one had an intermittant short. After a short clean all the guns are now showing good. So we are using that tube on the bench to test the following MS9 chassis.
Findings:
First chassis has already been recapped and we confirmed the vertical ic was good. Still dead.
Second chassis has also been recapped with a confirmed good vertical ic, it made a 'powered on high pitched noise' but no picture.
Third untested chassis seemed to emit a burning smell. Gonna recap that and fit a new vertical ic then retest it. Some corrosion has got to this one though, so we may end up using this as a donor if it's too far gone.
Forth untested chassis would power up then briefly display a vertical line before going into shutdown. Fitting a known working vertical ic resolved the issue. Gonna recap this one and soak test it before calling it good.
I've got some transistors on order and have also ordered some vertical ic's as I only have LA7837 ic's and not LA7838. Not sure when they will arrive so will update again when we have had another tinker.
I guess the next step is to try replacing the transistors then......
Vamino2021-08-24 20:28:00
8,292CR
2nd chassi
did you try turning up brightness on flyback…
sounds silly but i have had a monitor i thought was not on but was just turned right down
does this chassi power off after high pitch
high pitch squeal over load ain’t it?
x-ray protection shut down
Retroman8392021-08-24 20:56:43
Vamino
Insert coin(s)
2,700CR
I tried turning the screen on the flyback up on the second chassis slightly but I didn't want to overdo it, It wasn't a squealing noise like the coils or component resonating, just the noise you hear when you know something is turned on, it seemed to stay on tbh but again I didn't leave it powered on for too long.
Hopefully we can have another tinker at the weekend as I have another 2 x MS9 chassis that I've just pulled from the loft. Both of these were recapped a while ago, not sure if the vertical ic's are any good on them though.
Vamino2021-08-24 21:14:01
Vamino
Insert coin(s)
2,700CR
No idea of where to measure voltages or what it should read sorry.
Well we had another bash at this chassis.
I received the some mosfets so we replaced the K172 ( I think it was that one, otherwise it was the othert type), this didn't help unfortunately.
We also tried to read the B+ voltage but couldn't for some reason. I think we disconnected pin 2 of the lopt, put a light bulb in circuit which lit the bulb but couldn't get any reading on the multimeter. Also tried reading the voltage on a known working chassis but the bulb blew and we couldn't get a reading on that chassis either even though it is a worker.
Pretty sure we tried to read B+ from the correct points as we followed a youtube video and also a forum post from another message board where Grant explained what to do in order to read it.
Running out of things to try now!
Chassis has been recapped.
Vertical IC has been replaced.
Transistor has been replaced.
I guess buying some HOT's is the next step according to the shotgun process.
[*] HOT: 2SC4692 @ Q506[*] Diode: ESC021 @ D502
