Ms9-29
Vamino
Insert coin(s)
2,700CR
So we had another tinker session last weekend.
We now get something on the screen, but it wont display anything other than this:
Adjusting the screen volts, brightness, contrast, cut offs does nothing.
B+ voltage is at 76v. There doesn't seem to be any cold solder joints on the neckboard.
We've replaced:
Vertical IC
HOT 2SC4692 @ Q506
Power MOSFET @ Q901
Diode ESC021 @ D502
Different remote boards
Anyone have any ideas where to look next?
Thanks.
Vamino2021-11-04 22:50:37
8,290CR
what video source you using ?
15khz naomi
super gun
jamma cab
looks nice no burn
too bright!
you shouldn’t be seeing them bars
turn the brightness down till them horizontal bars fade out just a solid glow on screen no barsRetroman8392021-11-04 23:03:13
Vamino
Insert coin(s)
2,700CR
15khz naomi
super gun
jamma cab
looks nice no burn
too bright!
Using a MVS connected to an Astro City Loom.
Tried adjusting brightness etc as I mentioned in the above post. Shane did see a wisp of smoke come off the chassis after replacing the HOT. Not sure if that's related or not, but just thought I'd mention it anyway.
It feels like it's almost there.....
8,290CR
not sure about the smoke but
hot is working as pic is full screen and on..
is the adjustment controller pcb known good working ?
is there one cap on the adjustment/controller pcb?
like i know if that little bugger ain’t working correctly can give a few problems
maybe try replacing the cap on that.
are your vsync & ground wired right way round for the chassi’s female amp up connection
Retroman8392021-11-04 23:53:58
robotech
823CR
Already tried another remote board that was working on another chassis so it's not that
Anyone know what the chips on these chassis controll ?
Vamino
Insert coin(s)
2,700CR
Not sure what that was reading mate.
Will try and check it the next time we have a tinker.
I know it's a stupid question, but just to be clear, how should we measure that? By measuring positive leg of that cap and ground whilst in circuit and powered on?
Thanks.
gunblade
9,132CR
if 200v is not present then if you look in the flyback cage you will see a few metal oxide resistors, R519 should be 4r7 and i expect you to find it open circuit
If the 200v is present but you have no tube heaters there is another resistor R532 that should be a 3R3 or 1R5 or 4R7 metal oxide ( depends on what tube) and thats likely to be open circuit
Vamino
Insert coin(s)
2,700CR
Well we had another go at this chassis yesterday, and it seems we took a step backward.
We got around 3v at the cap on the neckboard, and just like you said the resistor @ R519 was showing as bad in the tester.
So initially we replaced that with a 4700 Ohm which we read wrong in the bag it was in.
After we realised our mistake we ended up changing both resistors at R519 and R532 to 4R7 resistors (4.7 Ohm 3 amp)
We measured the original resistor at R532 and we got:
So we replaced it with the closest one we had which was a 4R7.
So now the chassis has voltage at the cap on the neckboard, but once powering it on it rises to about 90 odd volts then goes into shut down.
Can you verify what resistors we should be using please mate?
Where we were working they were difficult to read in the light conditions with our old eyes, but I've taken a pic using a decent camera in the below pic. R519 is on the top and R532 is below it. It seems R532 could be a 3R3?
Thanks.
Vamino2021-11-15 21:44:13
Vamino
Insert coin(s)
2,700CR
Thanks mate.
Yeah we lowered the screen volts to min every time we powered it up.
I've just ordered some bits so will update again when we have another tinker.
