Ms9 retrace lines
TimRose
6CR
Hi guys another monitor to sort if you can help.
All I'm getting is a grey screen with retrace lines like this. This is with the screen voltage turned right down as well. I can't get it to go any darker. Could this be a flyback fault?
Ignore the spiral effect that's only on the camera.
I have replaced the rgb amplifier which made no difference so I pulled out the scope and checked for a blanking signal which I get like shown...
Perfect, next I check the output to each gun and as you can see its sending data, and appears to be shutting it down for the blanking cycle too.
I have ordered a cap kit but it's coming from the states. Any tips as usual are greatly appreciated. Cheers
TimRose
6CR
Hi gunblade, I heard you were the man in the know when it comes to monitors. So I should hunt in the power supply section then? Any idea where I can get a schematic from for this chassis. I've Googled it but come up empty :/
TimRose2016-09-25 15:18:17
obcd
3,830CR
The 200V B+ is a voltage coming from the flyback and not from the power supply. It's a winding that is rectified with 1 diode and leveled with an electrolityc capacitor. Maybe the flyback is having a bad solderting on that winding pin. obcd2016-09-25 18:17:09
