MTC 900/e power board dead.
Paul_in_nottingham
160CR
Was having a look today at another monitor issue I have.
I've got an MTC900E that was broken by a faulty Hanty 250 PSU. The fuses and diodes test fine, and the main transistor in the power board seems to meter correctly out of circuit.
However, I've today removed red wire from back of power section to try the lightbulb trick. The light was dead, with no volts going to the bulb, suggesting the power board is dead. (I did this without the yoke or anode cap attached, I presume I should have at least got something as there was no power to deflection board?)
Any likely culprits in the power board that I should look at further?
RGP
Meeter & Greeter
2,039CR
This will be an interesting one.
I hate 900E's as the power section can have multiple weird fails but they're pretty stable when running.
Normally you get unarrested B+ that you can't adjust and see 180vDC. It sounds like something open circuit.
I would check the fuses obviously but also go point to point underneath on continuity and check for broken traces.
I usually desolder both sp15 and 16 and use them on the two terminals of the bulb - is the frame a suitable 0v reference?
