MTC 900 flyback
mjnman
2CR
I need to replace the flyback on mtc 900 chassis, the board version 2 because there is a TDA 2653A (pins staggered on one side only) mounted on a "L" shaped heat sink.
From the scheme i saw EHT AT2076/50;
1. Can I use a HR6050? beacause some people said about HR6051
2. Are there difference between AT2076/50 and AT2076/86? both are HR6050 model.
thanks
mjnman
2CR
Please, a stupid info.
Which point of neck board is G2 and G1? from attachement the picture of neck board. I thinking G2 is PIN 1
I saw the RED PIN 9, BLUE PIN 3 and GREEN PIN 12
M K L
1,158CR
HR6051 is the correct replacement. HR6050 is a replacement for the Seleco BS500 TV chassis. There are similarities with HR6051 but it's not a drop-in replacement. Maybe it's possible to adapt it, maybe not. I never got around to trying it myself.
Those neckboard schematics are for the A51-211X (same tube as the MTC90) and they are in fact of the FB neckboard (p.14 of manual), not of the S4. Other tubes have different neckboards (p.13 of manual).
1 = G3 (focus)
3 = Blue cathode
6 = Heater
7 = Heater
8 = Red cathode
9 = G1
10 = G2
12 = Green cathode
M K L2022-05-17 21:24:46
mjnman
2CR
I googled and I found a deutsch forum with a picture of original MTC 900 chassis where the number of ETH is 551001003. The number matches with a HR6050 flyback.
https://www.arcadezentrum.com/forum/board/index.php?thread/27696-bildeinstellung-r%C3%BCcklaufstreifen/&postID=255626
mjnman
2CR
I think I have found the my MTC 900 flyback doubt.
The deflection board models "Hantarex DB 1" and "Hantarex D.S. 3" use a flyback HR6050, AT2076/50.
The deflection board model "Hantarex DB 2" use the flyback "HR6051, AT2076/51 or FAT3771 (compatible).
I searched with goooogle the service manual of MTC 900 deflextion board "Hantarex DB 2" but I didn't find anythink.
Please, someone have the scheme of "Hantarex DB 2" model for MTC 900?
mjnman2022-06-13 10:17:28
mjnman
2CR
I tested a FAT3771 (HR6051 compatible) and HR6050 (Diemen Model). Both work with MTC 900 deflection boad hantarex DB2.
The HR6050 need a focus pin out (or you can edit the neckboard focus but I don't how can do) and to add another resistor from 1.8MOhm R02 for the brightness in the neck board Hantarex HFB S4.
The AT2076/86, HR6050, didn't work because one pin differ from board point.
mjnman2022-07-13 08:27:42
XVO
3CR
I've got a few questions regarding your adventure finding a good flyback. I'm in a situation where I thought replacing my flyback one to one, the problem was that I didn't noticed it was that the hr6050 I ordered was a AT2076/86. So now I'm searching for a FAT3771 but haven't got any luck. Can you point me out where to search?
Thank you
mjnman
2CR
Hi,
in these time it's very hard to find a flyback HR6051 or FAT3771. I found in a small electonic shop in Italy from link in this thread. It was difficult to found reach agreement for shipment but I was able.
I'm sorry but I don't know where you can find another one.
I would like find another one for a spare (HR6051 or FAT3771)
Good luck
