MTC 9000 degauss issue
Purity
The Oracle
17 (100%)
2,999CR
Hey guys, I've got a degauss issue on an MTC9000. I have magnetic distortion on the left hand side of the screen, and I can't easily take the monitor out of the cab.
I've checked the fuses and they are ok. I'm wondering if it is the PTC? Is it possible for this to fail without blowing the fuse?
If it is the PTC can anyone link a replacement?
big10p
Coins detected in pocket!
6,093CR
Probably PTC. Do you hear the degauss at all when switching on? Think Swallow Amusements sell them. I would also check the coil hasn't come adrift from around the tube.
bones
1,628CR
A silly one but it's not plugged into the wrong socket on the chassis, had one plugged into the socket for use with a pushbutton rather than the normal one. Other than that it's beyond me.
8,308CR
Watching a vid last night
If the yoke has come away
Ever so slightly this can have same kind of effect
Slight discolouration around edges
May need slightly moving tight to screen.
Retroman8392022-06-06 12:15:35
Purity
The Oracle
17 (100%)
2,999CR
First thing I checked was that it was plugged into the correct socket, and it is correct.
Discolouration is only on the left hand side.
I do have one of those chinese death sticks, but it's in a cocktail cab so hard to zap it properly. I don't know if a drill might be better? Will Youtube the method
