MTC 9000 wobble
RygarR
413CR
I've recently picked up a refurbed MTC 9000 and fitted it into a Goliath cab. The monitor gives nice strong
colours and has good geometry, but there's a bit of a wobble on the
vertical. Don't know if this is due to a dodgy pot, or cap, or grounding
etc. Any advice would be greatly appreciated.
If it helps, I had to increase the vertical size of
the image to suit my mame set up. On reboot from cold, however, the
image started too big, but gradually shrunk down to the right size again.
Cheers,
A
RygarR
413CR
Right I've had a quick shuftie at the chassis, and all of the small electrolytic caps look new. The LOPT is also new.
Tried it with a 60 in 1. It still did the screen shrinking down to size thing, but didn't seem to wobble.
Put the j-pac back in, and the wobble was there again. More noticeable on some games than others. Also noticed a kind of staggering of pixels in alternate rows going on with the lettering on the high-score table on Robotron. Wierdly, doesn't do it on other screens
Until recently, I had the j-pac in another machine with another monitor, and it didn't do any of this.
tb2000
3,578CR
I was going to say try disconnecting the degauss wire but it sounds more like the area Grant's mentioned.
RygarR
413CR
OK Dudes,
Took a while to get to the bottom of this.
Tried messing about with the gain pots, and adding a twin USB cable to the JPAC. Neither made a huge amount of difference.
After fiddling with the adjustment pots again, I noticed that one was a bit dodgy - twisting it did the trick, but nudging it gently upwards caused the image to shrink instantly to half size.
Took the board out and lo and behold
Swapped it with the adjustment board on my other MTC9000 and managed to solve the problem on this monitor - but transfer it to the other.
At least I know what was causing it now!
