Hi there, I bought an mtc 900e which was dead on purchase. After finding issues in the power section I replaced the one of the rectifying diodes, big filter cap and a couple of transistors (tr6 bf671, tr7 bc237b ) which were found to be bad. I then had power and the b+ was 174v with a high voltage shutdown, after pulling the IC2 (tda 2593)and reseating and and replaced the SCR transistor type thing I then had life! With a signal attached I had a clear image but with a lot of waving on the screen and the b+ anywhere from 134vdc to 148vdc, without a signal the b+ is steady at 148vdc and cannot be adjusted - somethings not right!
I have also recapped the entire board.
I suspected the problem could be in the power supply section but am really struggling! Anybody have had any similar issues and could point me in the right direction. Any help appreciated,
