MTC-900E repair help
Ronnie Dent
1,206CR
Working on this 900E it has burnt out resistor on the red drive? Was thanks as per Tony's suggestion one of the pairs of transistors above would be short but they seem to read ok, there is another smaller transistor also in the red drive but not sure that would melt a resistor? Anyone point me in the right direction please?
P.s screen powers up with a bright red raster
Thanks Ronnie
tb2000
3,585CR
You can try changing the smaller transistor but I don't think I've ever seen one of them cause a burnt resistor. I'd still change the larger transistor (possibly both) even if it seems to read ok.
Ronnie Dent
1,206CR
Thanks guys, I did fit a smaller 1/4 watt resistor (should be 1/2 watt) but it instantly started to smoke! I know I have one new transistor and a few pulls may try swapping them out,
Cheers Ronnie
Ronnie Dent
1,206CR
Changing the resistor and both the transistors has cured the red raster I now have a nice white raster so all looking good, yet to test with a signal but hopefully it will be all good.
Thanks Ronnie
