mtc900/e missing blue RESOLVED
tronads
453CR
Where would be the best place to start looking at on a 900e Thats missing blue. Ive confirmed that blue is reaching the chassis rgb input connector by swapping the colours about, and any color on blue input produces nothing... And all 3 signals produce a picture on red and green.
I was thinking of starting by desoldering the red and the blue on the neck board and swapping them over...reasonable place to start ?
I do have a scope but I'd rather not use it as I'm working in a very cramped area and its huge....but I'll use it if I have to.
Any pointers ?
tronads2014-03-25 18:49:06
tb lilley
5 Star
1,686CR
Had the exact same problem on exact same monitor a few weeks ago. Turned out to be a dodgy pot on the neck card. Just gave it a tap and now works again. I can recreate the fault at will simply by touching the pot. Should resolder or replace really.
PaulSwan
ZZZ
1,118CR
If you set up your scope and follow the blue signal input along on the schematics it'll probably be less time than any other way. Likely in minutes you'll know where it's gone.
I've had missing colours due to both the small signal transistors right across from the inputs and also the larger drive transistors on the neck board.
There isn't much to it - the scope will tell you what you need to know.
Paul.
PaulSwan2014-03-19 20:18:30
tronads
453CR
Cheers guys. Looks like I'll be busy on my day off tomorrow then.
As long as the gun itself isnt gone, this is only going to be a few quid to repair....its just the time, and the fact that I am sh1t scared of monitors !
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
i was the same sh*te scared of monitors but i brought a discharge probe and all the correct meters and don't take risks. keep your left arm behind your back when discharging and its pretty straight forward
just don't do no cowboy discharging with a screwdriver and get your self a proper probe and you will be fine
tronads
453CR
Discharging this isnt going to be an option, I will be fault finding with it running as Paul suggests.
Given the nature of the "channels" RG and B go down, and their cloned circuitry, it should be pretty easy to compare each one at the same points, until something goes different on Blue.
Given it was working fine before transit, I suspect the issue may well be more something like a dry joint rather than anything failed.
jengineer
49 (100%)
1,205CR
mtc900E are notorious for having dry joints on the transistors on the neck board, give them a gentle wiggle and watch the solder joints move on the other side
tronads
453CR
I have now resolved this issue. Took delivery of some BF871 transistors today, and went to where I had already narrowed the issue down to....TR27. I had already established visually that this had been replaced in the past at some point from the look of the soldering, which looked "fresher", and the chassis had also had a cap kit fitted at some point....which is nice.
Snipped its legs and went to desolder the pins out, but on flipping the board over, the emitter track was just hanging off the board and as soon as I melted the solder, the pad just just fell off, leaving about 5mm of copper track missing.
Soldered in the new one on its base and collector, and looked at the circuit diagram for the emitter, figuring I would have to solder a link wire in there, but could see it just went straight to the collector of TR26, so as it was in reach, I just bent the leg over and soldered it straight to it, using its own leg as the link.
Picture now perfect, and I have a smile on my face again.
strykr
1,351CR
Nice one Tronads
