MTC9000 and Jamma?
tonyg64
22CR
Hi me again with another question if I may :)
Im looking at replacing the main Jamma loom in my cab as its all a bit tatty.
On the monitor chassis (mtc 9000) there are 2 multi plugs, the Jamma side and what Im guessing is the mains (ac?) side on the 4 pin plug.
Anyway im tracing the wires from the plug on the chassis to make sure they go the correct place on the Jamma connector.
So Blue goes to 13 as per the diagrams
Green goes to N
Red goes to 12
Black goes to 14
Now here is where Im confused:
Yellow from the green plug says SV on the sticker and is not connected (a length of wire is there from plug but does not go to Jamma plug.
White is labelled HS and goes to Jamma P but the pinouts say Jamma P should have HV. Whats going on here?
Question 2: My cab is not wired for 2 player control ie you cant fire or move but game is playing. Do the player 2 wires from the Jamma loom connect to the same terminal as the 1 player or is there a spare terminal on the switches for player 2?
Tony
simonden
20 (100%)
1,042CR
The yellow wire on the MTC9000 is Vertical Sync (VS), the white wire is Horizontal Sync (HS) but can also be used for Combined Sync (CS) of both the Horizontal and Vertical (HV).
JAMMA outputs CS (or what you are seeing as HV) so just need to connect the white wire on the monitor to the JAMMA pin P.
That depends on what you mean by 'terminal'. The wires from the JAMMA loom should connect to the p2 buttons joystick, but whether your cab has a separate connector or not, you will need to trace the wires from the P2 buttons/joystick and see where they are going.
tonyg64
22CR
Thanks for the quick reply; so as mine was connected thats correct then yes?
There is only a single joystick and 3 buttons each side. I only use 1 button to fire and the stick. The buttons have a spare spade terminal there but I havent put a meter on them to see what they do yet.
If the game board sees a second player as a different score etc will it matter if the 1 and 2 player wires are soldered to the same point?
Tony
tonyg64
22CR
So to summarise this, if using single joystick and needing 2 player, only connecting P1 to the buttons and stick is needed? P2 start button connected of course. If so my SI DX wont play so either a board problem (or setting). I want to buy a new harness for the cab and want to make sure I get the right one and not find out later I need "type b" for example.
Tony
simonden
20 (100%)
1,042CR
I don't understand what you mean by 2 player with a single joystick?
Some games have 'alternate' 2 player mode, this means that you only have 1 set of controls (just player 1) and 2 start buttons and each player takes in turn to use Player 1 controls. In this setup, you do not have player 2 controls except start button connected.
Other games have 'joint' 2 player mode. This means you both have a set of controls each and play at the same time, so 2 joysticks needed.
Space Invaders DX is a 'Joint' 2 player game, so you need 2 joysticks.
tonyg64
22CR
Yes alternate is the right word. Ok that explains it then. Like my Taito upright SI you have alternate players with the same controls. Would you happen to know if Air Buster is the same ie 2 sets of controls would be needed?
Tony
tonyg64
22CR
Ok thanks
Tony
