mtc9000 cap
jengineer
49 (100%)
1,205CR
just pulled out a 9000 chassis, fired it up, it has a sort of distorted and shaky enlarged screen,
chassis is dirty as hell and in dire need of a cap kit but I've just noticed the big cap is 330uf when they are normally 470uf?
can someone confirm it should be 470uf?
(the switch is broken but its been linked out underneath)
jengineer2015-01-05 23:41:44
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
Yep 470uF 200volt. 105c
I did have spares but only have one left which is a complete cap kit. And want to keep it together.
Btw you do know the switch is broken. Down by the rgb connector. silverfox07862015-01-06 01:40:35
jengineer
49 (100%)
1,205CR
yes do know the switch is broken but its been linked out underneath,
I just thought there could be a variation of this chassis with a 330uf cap?
I have full cap kits bud
RGP
Meeter & Greeter
2,039CR
That's the mainline input filter cap, they're usually a bit overspecced to hold onto the AC voltage for a bit longer on the voltage drop caused by load after the bridge rectifier.
Ideally you should replace it with the 470uf/200v cap - this is one circuit where the voltage needs to be right but the microfarads can go up due to what its doing.
Everywhere else on the DC side you should stick to the right uf and match or increase voltage.
I'm only saying this because i've seen a few mainline caps that aren't the exact ones but running fine. You only have about theoretically 128-140v AC coming in on that point.
I would still replace it with the right one if you're doing maintenance although it might not be the cause of your trouble.
I agree with the more proficient experts that this cap doesn't go wrong that often but not to say that it hasn't.
RGP
Meeter & Greeter
2,039CR
My knowledge is only a zillionth of people like Ordyne and Gunblade on this aspect, you can never beat their experience.
I'll always offer an answer where it makes sense or from my experiences but am always happy to be positively corrected - it's how we learn
