mtc9000 fault
jengineer
49 (100%)
1,205CR
I've been working on a mtc9000 for a few hours now and after bringing some life back to it, it has a picture issue where it seems to display double in red,green and blue
new lopt fitted
re-capped
a couple of broken tracks
a few dry joints
swapped neck board for different one
any ideas? pics below
jengineer
49 (100%)
1,205CR
ok I fiddled around with the neck rings and got it like this, do you reckon it looks right?
it is in deed an Orion tube, but this is common on Hanty 9000's
jengineer2017-05-12 06:31:52
Ace`
PlanB contributor #1
40 (100%)
4,038CR
It's easier to tell if it's spot on or not using the cross hatch and colour bars, cps2 boards have both of these in the test menu.
tb2000
3,579CR
Yeah looks good. If there's any paint marks on the rings then that should normally show where the rings should be. Can you get the focus any sharper? Is the purity ok as well?
tb20002017-05-12 14:50:55
Purity
The Oracle
17 (100%)
2,999CR
I'm fine fella, but thanks for asking
big10p
Coins detected in pocket!
6,091CR
Are you saying there's still an issue? It's hard to tell from a photo. As tb2000 mentioned, it's worth checking the colour purity, too. You'll need to find a game screen test that displays a separate red, blue and green screen. If you see any patches of colour impurity, you can adjust the pair of purity rings. I think they're the pair furthest away from the neck board.
