Mtc900e stable but split image cause?
stevebm1
39 (100%)
1,269CR
900E,it has the standard rgb connector,I have tried another chassis on the tube and it is fine,the image is correct,it’s just this one,I was testing that has the split image
gunblade
9,096CR
there are a few things going on with the chassis, red seems to have a fault and that half locked image.
the vertical hold and lin pots corrode and can give odd issues like this
the contrast is too high as well
it is possible a leaky transistor in the sync circuit is preventing full lock
all the usual standard mtc900e issues
gunblade
9,096CR
these chassis suffer so much from age and corrosion, the pots and small signal transistors in particular plus the neck card drive transistors and glass diodes - these can become such a massive job
tb2000
3,571CR
Yeah, i've fixed them before where they've been on test and transistors have gone down one by one. For example, left one on for 30 minutes, transistor went on neckboard, another 20 minutes, one goes on the rgb mixer section, another 30 minutes, one goes on the neckboard, then it could go an hour before another goes down, and so on. If I get one like that I just tend to change all transistors on the neckboard (as when the BF871's go they often take out a resistor as well) and all transistors in the rgb mixer section. I had one a while ago that had a vertical size problem - changed the pot but it didn't really make much difference. Took a while to work it out but it turned out the new (new old stock) pot I put in was faulty!
stevebm1
39 (100%)
1,269CR
Since I managed to sort out the. Hold problem,With the signal disconnected,i still get a red screen,I desoldered the red wire from the neckcard to see if that made a difference,but it still stay red now
stevebm1
39 (100%)
1,269CR
What’s the location of the transistors that are the rgb mixer signal ones you and gunblade mention to check?
