I have an MTC900E USA-model here (the one with the separate 3-pin connection for negative sync signals)
and I'm having troubles getting image to fill the screen area.
- inputting image from a Hyper Olympic board ( I got 2, a bootleg and an original, both same problem)
- monitor chassis recapped
- tested also with a Green Beret bootleg which seems to give a "wider picture" by default and therefore doesn't have this problem
- horizontal width coil has been rotated fully up and there's still 1cm black borders around the picture
- cap C42 unsoldered, tested for correct value and replaced with one of higher value as a test
- cap C69 unsoldered, tested for correct value and replaced with one of higher value as a test
Still no effect.
What to do, please help
Also note that there's a problem with both of the Hyper Olympic boards so that
they display wrong colours. The image is however stable as a rock.
I'm using the negative sync inputs.
Thanks,
Toni
ttcaven2015-05-25 10:17:00
Still no effect.
Thanks,
Toni
