multiple AC wiring
virtvic
The Cabaret King
21 (96%)
2,012CR
I've been wiring up a cab and there's quite a lot of separate AC wiring that needs to be combined and it's a real struggle to get it all joined together on one terminal on the transformer.
What is the best way to do this, so you don't have 4 or more spade connector (ring / 'c' connectors) attached to one screw terminal?
I bought some multi spade connectors a while ago and can't seem to find them, as I don't know the real name for them? They were a white plastic unit that can be screwed down and had a bunch of spade terminals that were all joined each side (allowing neutral & live on one block) The Earths all go together on ac common screw connector.
virtvic
The Cabaret King
21 (96%)
2,012CR
Kinda. The ones I had were white plastic and had 3 lots of 4 terminals - so you could attach and splice a full AC wiring from 4 sources to a single one (L/N/E)
virtvic
The Cabaret King
21 (96%)
2,012CR
I'll probably just make myself some from rectangle stainless bar and nylon fixings.
Those are the sort of thing, but not exactly what I've got before. If I could get to one in a cab easily, I'd post a picture of the exact parts I'm on about...
Thanks!
8,288CR
Not sure if this would help
But you would need linkers..
Not sure if you have ever wired a hob?
They have linkers - copper bar that links terminals
This is available on Amazon
22€
12 ports, all fused
I use these we use them at work
NHBC certified 240v compliant and insulated..
Tiny & easy Retroman8392022-05-29 21:24:53
