MV-1A No Audio
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
I have an MV-1A Board that seem to not be outputting any audio, its not the carts I have tested that
the caps look good, when I turn the volume pot I get crackling
What do you think it could be
Also what make and model is the op amp and what value is the pot I can try changing those first
bbz149
26 (100%)
1,608CR
Could be the Audio amp chip?the one held down with 2 bolts. lookup the data sheet for the input and connect an external amplified speaker to it maybe to check its getting any input. Also do you get audio hiss when the volumes turned up? also if you know which pin is the audio in, do you get audio buzz when you touch it?
RaveN
1,325CR
You can check the pot by measuring the resistance across it (so that you don't unnecessarily replace) it).
You can also use your MM set to DC and measure the voltage on the +/- speaker outputs. There should be no (or minimal) DC. If you see a high reading, then either your Amp IC is dead, the DC coupling capacitor isn't working, or something else in that circuit (although at least you can narrow it down by following the DC).
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
I made the mistake of ordering a new MM from China, it still hasn't arrived yet so cant use the MM test but with that said the Volume POT looks dead, it just spins when you turn it without stopping, what is the value of POT I need as regardless of the fault the POT needs changing. after that I can look at the ICs.
