A battered MV1FZS board arrived today which I'll be using for unibios.
Going to have to give the board a bit of a clean as there appears to be some corrosion on the underside, not sure if its actually dirt at the moment.
Either way, battery replacement wise, its not leaking, but you can tell its not far off.
It's already a cell style battery.
Can't decide with whether to remove completely, replace with a Panasonic rechargeable, or get it running of standard 3032s?
Also, the underside "heat pad" that covers the battery solder points, is that salvageable, if not what have people replaced it with?
