MVS 1 Slot HELP !!!!!!
TheDaddy
14 (93%)
7,230CR
Hi guys/gals. So I have been ill for 8 months so this weekend is my first time back in my repair room for 9 months !!!!!.
This is my first attempt at repairing one of these as I normally do older stuff.
Anway the issue I am having is with a MVS MV1A Single slot, I have 2 of these (Identical) and 1 I am using for spares and does not work at all (Prety sure its a custom chip that generates the clock signal !). The other one from ebay with " L@@K FULLY WORKING MVS !!!! "from china that arrived with audio and video issues & does reset from time to time, With being ill I just tested it and stuck it to one side and could not be arsed to contact the seller.
Because of the issues I socked the Bios and fitted a socket so I could use the test rom and 3.3 Bios. ALl tests came back as ok - Although when I was trying to play the game there were some errors popping up.
So I got both of them down to the main boards and one looked like it had been modded (The one from ebay ) Image below is of them both :-
So my first question is why has someone replaced one of the buffers with a dummy blank ???
With there being graphics issues (Seems to get worse the longer its been on) and this plastic thing had replaced the original chip I decided to remove it and fit the correct chip from the donner board.
Plastic Part Removed :-
Fitted new chip :-
All looks ok ( I Think ! ) - So booted the system up with a game and now all's I get is the cross hatch ? I have checked everything several hundred times and even replaced the old plastic piece and still get the cross hatch !!!! ( Re fitted the chip again after ) I assume I have killed something somewhere but can not find any diagrams for this and am very confused to as what I may have done.
System passes the normal tested but when I do a Cart test on reset it fails on Z80 but I think this is because its not detecting or getting info from the game cart.
I have also done the memory test with the cart inserted and I get these results :-
Memory map :-
Video Ram - Empty ??
Anyone have any ideas on how I can move forward with this ???
Thanks,
Dave.
Ace`
PlanB contributor #1
40 (100%)
4,043CR
The chinese repair guys use that replacement neo buf flex pcb to replace bad buf chips where they can (not all can be bypassed like this) and they also use them in places they can to nick the original buf chip for other repairs.
Looks like you've taken a working buf bypass and replaced it with a bad buf chip. They're made by fujitsu so are dropping like flies.
TheDaddy
14 (93%)
7,230CR
Thanks Ace , I have replaced it with another of a donner board and still dead. I have also damaged a track now !!
Dave.
Ah just noticed this :-
https://wiki.neogeodev.org/index.php?title=NEO-BUF
TheDaddy2019-10-26 20:46:41
