MVS arcade has stopped working- help?
Moremonj
17CR
Hi,
New to the forum, i recently acquired a arcade cab that’s been converted to MVS. All was good for a few weeks but unfortunately I dropped my spare MVS board on the power supply whilst the machine was. The trip switch in my home immediately blew. After turning the arcade back on it was dead apart my Marquee light blowing.
Had someone out yesterday who changed the power supply, with the power supply plugged in using an external cable and not the transformer adaptor the board came to life as did the coin mech but nothing on the monitor.
When he attempted to plug in the transformer plug(kettle style) into the new power supply nothing at all came on, not the board or coin mech. Voltage pen suggest power was there nothing coming on?
Any advice? Sorry If my terminology is horrendous but I’m new to all this. Moremonj2020-07-24 22:45:23
Sbdesign
SEGA collector
16 (100%)
1,721CR
its hard for me to understand what you mean.
But If you mean when you put a kettle lead into the rear you get no power out the other end, then it could be simply the fuse thats normally hard to see the pull out section holding the fuse.
is this what you call a transformer plug?
Sbdesign2020-07-24 22:33:19
Moremonj
17CR
Hi,
yes, the transformer plug is like a kettle plug and when I plug this into the new power supply I get no power to anything yet my voltage pen confirms there is a voltage going to all aspects.
Yet if I use an external plug from the new power supply to the mains I get the mvs board and coin mech working.
I have changed the fuse on the mains plug and the transformer but this has not changed the outcome unfortunately
Sbdesign
SEGA collector
16 (100%)
1,721CR
sounds like this device is blown, so you need a new EMI filter imo
if you are calling the picture above a transformer
if you are saying the following ....
3pin plug=======jamma power supply(on)=====game(on)
BUT:
3pin plug kettle lead(fuse in plug ok) ======emi filter fuse (tested working) ====EMI filter out (no power) ===jamma power supply(off)=====game (off)
Id personally assume and buy a new filter socket
Sbdesign2020-07-24 22:55:11
Sbdesign
SEGA collector
16 (100%)
1,721CR
oh and the reason nothing on monitor, is because this will be connected to back of emi filter also, so if you trace the wiring you can see for yourself, so if no power there, and power only direct to PSU (which is to power boards, not monitor) won't turn monitor on
Sbdesign2020-07-24 23:01:17
jonhughes
1,156CR
It is common to find a fuse in the line filter and it’s also common to find fuses on the underside of those transformer blocks. Unscrew it and take a look underneath. You need a continuity meter / volt meter or it will be mostly guess work trying to find where the fault is.
Moremonj
17CR
Thanks Jon,
I removed it last night but could see no more fuses but I have been told there could be up to 3 in there[only 1 visible] by the guys at Retrolesiure
I thing it may be case of shipping it off to them.
Sbdesign
SEGA collector
16 (100%)
1,721CR
What cab is it?
Whats model number of transformer?
Take some more pictures once you unscrew and look underneath like jon said.
Its something simple, I certainly wouldn't ship a cab off due to this issue.
jonhughes
1,156CR
I can’t see much from the photo but before you do send it off try let’s try and find a way. Can you take a wider angle shot of the distribution block and more photos of the inside of the cab, I’m wondering if one of those dead man switches could have gone also, I’ve had two go on me in time and they just take the power out. I’ve had a similar looking distribution block in a Galaxian cabinet and there was a fuse linked with each power out terminal.
Moremonj
17CR
Picture of the underside of the transformer above
The new power supply I’ve had installed I’m wondering whether it’s either capable of power the unit.
Moremonj2020-07-25 15:05:41
Moremonj
17CR
I have not checked the door switch personally but the gentleman who changed the power supply did and said he could find no issue.
The issue im such a novice I don’t really know what to look for, had just hoped the power supply will resolve all issues but unfortunately is not the case.
I’m sure someone could fix it easy but I thing I may have just ship it off and let someone do it and take the costings on the chinMoremonj2020-07-25 15:33:03
Moremonj
17CR
If there is anyone local to South Wales who has a history in repairing arcade machines please drop me a message. I’m more than likely sending it off the Retro Leisure the end of the week as I honestly have no experience of finding the issue.
I had someone look at it but they just changed the PSU
(Possibly not compatible) but hasn’t fixed the issue unfortunately.
Obviously happy to pay if it can be fixed
