I’ve an mvs 1 slot and it’s showing this image ,it’s not the usual image I’ve had from other broken mvs boards
Does anyone know why it’s like that ?
I’m assuming it’s the board and not cart ? I’ve no others to check with it at the min
It could be the cart or the motherboard, crosshatch bascially means the motherboard is running but it hasn't detected a cartridge. It could be as simple as dirty connector or cartridge pins.
Clean the cartridge with some iso alcohol. Turn the mother board off and spray a bit more alcohol on the cartridge and push it in and out a few times to clean the slot.
Leave it about 10 minutes then try again. If not working still, try putting the cartridge all the way in the pulling it out slightly on either side.
If it boots to a blank screen after that, check the pause dipswitch isn’t down. It’s dip 7 or 8
