Nac 9 yoke
8,292CR
Help needed Trying to fit a chassi to this monitor
I have Toshiba A68KJU96X (8D) at least it says 8d on label.- with Windy (PB6643-1 chassis)
But hori pins further apart on chassis
Arcade otaku wiki has this tube and chassis as compatible?
So I turned attention to the yoke thinking maybe yoke has been swapped?
This is the yoke
Measured yoke wire connector 10 mm apart
And the hori pins on the chassis
And the chassis is the pb6643-1
Yoke is new astro city
And tube label says ms9 29se. Sega... did sega use a different chassi in new astro’s?
And that’s why the pin spacing are wider apart ?
And my chassis is like for an older type revision tube ?
All other connections fit ok,
Is this chassis compatible still as stated on arcade otaku or is the nac-9 yoke not compatible with pb6643-1?
Retroman8392020-04-27 17:45:24
M K L
1,158CR
That wiki page needs to be edited. All those tubes are in fact the same tube. Number+letter is just the manufacturing date: 8D = April 1998, 7F = June 1997, etc.
8,292CR
lol ok...
so i need an ms9 chassi for a new astro city...
any idea why my toshiba pb6643-1 chassis has 15 pin spacing?
like an early date chassis i guess ?
can i just spit it you reckon ?Retroman8392020-04-27 19:06:37
Sbdesign
SEGA collector
16 (100%)
1,721CR
Maybe no help, but there is a hole not used on the chassis plug that looks to be the spacing you need.
That might have something to do with it
8,292CR
Yeh i has no pad through on the underside no trace to the whole..
I could just make a split the yoke connecter
I will take yoke readings tomo but I Guess I can find this on net
It must be compatible .. if long list on arcade otaku includes it...
Just wondering if anyone has a tube with 15mm spaced yoke connector to suit this chassis?
I think it is this chassis that is odd must be an early toshiba pb6643-1? That went with a different monitor
A monitor that had a yoke with 15mm yoke connector
