RGP said:
I fixed one of these boards not long ago with input issues going through these resistor packs. Bad solder was partially preventing the connection for sure and a bad 74HC257.
@John, let me know what you have wrong with your RT board, I could swear I recorded my repair and it was a dead to working one so might have some interesting stuff that would help.
Look in fix logs, I might have written it up there. I'll have a look through all my memory cards asap as it was a good one.
Thanks - is it the post where you had bother with TTL and CMOS? I'll check that as I attempted to fix it back in 1998 (!) and may have screwed it up more.
It's stuck with both processors in loops refreshing the watchdog and reading from RAM, as if they're waiting for something. The 8000 is a watchdog refresh (It's writing) and the 4182 is the RAM access. Slave CPU is doing something near-identical (but for a different RAM address).
It's stuck at startup - you get about 5 brief screens of garbage (lots of small squares) and white noise on the audio.
I did scope the signals with an analogue probe and I couldn't see anything obvious. Hard to know what a knacked signal looks like when 5V means somewhere between 3V and 4V on TTL. Nothing was stuck.
I was trying to use it as a learning exercise rather than replace every chip on the board, although I have swapped all pluggable ICs with those from another board to no avail. The logic test was done with the sub-board removed, but it should run to the game and watchdog reset with that removed.
*Sorry about the thread hijack - will start a thread if I run out of things to try (trying to understand the MAME driver, schematics and 6809 datasheet at the moment.)John Bennett2016-04-09 07:46:19
