Naomi 2 issues
channel27
1,377CR
Hi all,
I've just picked up a Naomi 2 motherboard and VS3 but it's behaving oddly.
It boots, passes the Sega and AV opening screens but then goes to a black screen with Free Play at the bottom and nothing else.
Also, whilst I can get into the test menu, pressing select does not move the cursor off of EXIT.
Any ideas, knowledgable peeps? :)
Thanks in advance,
Rob
glstar
160CR
channel27 said:
Hi all,
Thanks in advance,
Rob
It could be some bad roms into the virtua striker 3 cart.
I have one cart doing the same and it's broken.
channel27
1,377CR
I've got the test menu working with the IO board disconnected. Chips IC107 and IC109 report as bad in the ram check.
As I got the board cheaply in a job lot, a repair may be economicaly viable. Does anyone on here do surface mounted work? :)
