Naomi 2 ram - FIXED
channel27
1,377CR
Hi all,
Are the ram chips used on Naomi motherboards available off the shelf, or would it be easier / cheaper to find a donor Naomi?
I've got a Naomi 2 that is reporting 2 bad ICs which I'm using as the perfect opportunity to get my SMD soldering game on.
I had a Naomi 2 motherboard that was reporting 2 bad ram chips (107 and 109).
robotech kindly gave me 2 replacement chips from one of his spare boards and, in my first go at surface mount work, replaced IC107 this afternoon.
All chips now report as good, so I assume, as 107 and 109 are physically on top of each other on opposite sides of the board, they share the same bus and the bad 107 was causing 109 to report as bad too.
Many thanks again to robotech,
Cheers,
Rob
channel272017-06-18 18:03:05
Ordyne
1,282CR
Sounds like they may be around a GPU ? If so you have a 50% chance its the GPU and not the ram.
The ram is nothing special but you may have to resort to ebay to buy it in low numbers.
channel27
1,377CR
Thanks Ordyne.
The Naomi boots and shows the game's opening sequence but then stops. Hopefully it's just the ram and not the GPU.
I can't find the chips on eBay, Farnell, RS, etc.
Can someone point me in the direction of where to find these or something compatible, please?
Are both of these the same as the only difference is 9017 > 9020. I'm guessing that's just a serial number?
yoganuggy
654CR
sorry to bump an old thread.
The D4564323G5-A10S-9JH chips seem to be unavailable but there are plenty of D4564323G5-A10-9JH.
Does anyone know if the D4564323G5-A10-9JH is a drop in replacement? (no S after A10)
