Naomi bios problems
8,308CR
Trying to get net boot going
Bought bios Japanese
EPR-21576h
But when inserted. All I get is blank screen
Any help massively apretiated ?
My Naomi says it is export vertion
richmal
14 (93%)
204CR
If you are getting a blank screen it sounds like the bios hasn’t been burnt to the emprom properly.
Are you pressing the test button on the Naomi motherboard and accessing the test menu to find it is an export version?
8,308CR
yes i am hitting test button ,
and yes i totaly agree with you about the bios chip
im totaly gutted as i waited ages for it to come from spain
then got pitools
and all fired up , then been swaqpping out bios chips switching dips up and down making sure
net dimm is all good , etc,.... etc ....
you know and guy on flea bay is alll take a phot off the chip and send me a pic!!!!!!
i will send him a pic all right a zero pic strieght up the shvincter !!!!
anyway i guess i will enjoy more when eventually i find a good multi bios chipp ,, any ideas where to get a good chip from ?
regards dan
obcd
3,830CR
Are you sure the new chip is seating fine in it's socket? I see no reason why someone would send you an unprogrammed or bad eprom. (Unless they sent the wrong one.) If you know someone locally with the right programmer, he could read out the eprom and eventually reprogram it.
8,308CR
Put Scott’s multi bios in and all good -
Thanks for all the help
To all
Well happy all good
Just sound issue
Get six buttons in
Topper coming from bonehead
And I will start cleaning re spray etc ....
cannot wait to get started
digweed
368CR
Chunksin said:
Send Scott a message via https://www.ebay.co.uk/usr/jelacooma?_trksid=p2057872.m2749.l2754 - ask for a multibios and he will hook you up
Yeah I used him as well before on Ebay, sorted me out with piforce tools and everything
penrhos
747CR
If your desperate- I can do Naomi, mvs, g-net, stv bios chips and Naomi zero pics.
Can't do lindy zero pics though - which is a pity as I need one myself.
Anything a gq-4x or 866cs can burn. At a push i can dig out the dataman S4 but it's a bugger to use on a modern pc.
