Naomi cab maximum resolution
channel27
1,377CR
Hi all,
What’s the maximum resolution that a MS2932 can output?
I thought it was 640x480 but I’ve found a vid of a Crazy Taxi cab running Outrun 2 off a Lindy @ 800x480
https://youtu.be/8aJEDLF_skk
Is that running on the stock monitor?
Or rather, can I drop a Lindbergh into my Crazy Taxi to play Outrun 2? :)
Cheers all,
Rob
Brettster
1,292CR
You can play or2 sp from a lindy if you have one of the multi game hard drives as it has a hacked 640x480 with 4x anti aliasing mode
channel27
1,377CR
Ah, yes, good point. I hadn’t notice that, thanks.
Can Outrun 2 on Lindbergh output at 640x480 via the dip switch or is that likely a hacked multiboot?
Also, do you know if any other Lindbergh driving games output at 640x480?
Cheers,
Rob
