Naomi Cabinet
tazfaedodge
91CR
Has anyone striped one of these down?
Did you take photos?
Got the cab back one kinda one bit, but I have all these bits left over mostly the wiring and how it routes through the cab where all these earth straps go.
I wish I had paid more attention when it got dismantled
Nick
mathj
499CR
get some pictures up on the bits your not sure on
here are some photos of mine before i striped it down
http://1drv.ms/18YuYSp
hope they help
p.s and yes i fitted it in a VW polo
mathj2015-03-07 00:59:11
tazfaedodge
91CR
Thanks for the links will have a look when my eyes start working again.
I left some bits behind when I picked it up so just waiting for them to be sent over and I forgot to take my camera with me. Numpty eh?
Nick
I had to fit mine into a Dodge Caliber boy I was glad that it was a cut down
tazfaedodge2015-03-07 01:50:26
tazfaedodge
91CR
Have now taken some photos of the connections.
Also can I tap into here to take the power for the computer so that I don't need to have lots of cables hanging out the back.
I also rotated the monitor, So if anyone has a spare back give me a shout.
Nick
ZedEx48K
8-Bit
1,425CR
Pink & blue is the 110V, you should find most in there will only pair with one particular plug or port.
To tap off for a PC you would have to do it at the back where the filter is, that's 240V before it heads off to the transformer and gets dropped down.
tazfaedodge
91CR
Thanks the photo that was to go with the comment failed to upload
Where does the light bar plug into?
I think the first one plugs into the amp (that I left behind)
So I take it the others plug into things that I'm not using
Nick
ZedEx48K
8-Bit
1,425CR
I can't remember if the marquee light is 110V or not (I think so) and the power lead for it goes up the right hand side leg.
If you were to change to those LEDs ( I used the standard white ones once and they were good) you would have to run a 12V line up there (tap it off a PC molex plug).
tazfaedodge
91CR
rcantor77 said:
Does the Naomi now do Virtuality..?
The screen was vertical so now is in the horizontal.
Is there a button available that could be fitted in the blanked off slot next to the coin mech that I could use as the coin in?
Nick
