Naomi Controls
tazfaedodge
91CR
This might be a stupid question, but I'm still gona ask it.
Since the Naomi Motherboard has a USB input for the Control Panel would it take the input from my IPAC2?
For a bit of contents I have a New Net City that when I got it only came as a shell with the monitor and PSU. I have since MAME'd it adding an old computer and and IPAC2.
There was on other parts for the controls. So could the Ipac take the place of the Naomi's USB interface?
Nick
obcd
3,830CR
The naomi isn't an usb interface , it's a JVS. It just uses usb connectors and a standard usb cable for it's connection. A JVS is an RS485 interface at 115200 baud. So, I am afraid the answer is no, unless the naomi would also have an usb port that can be used to connect an usb hid device.
tazfaedodge
91CR
Thanks, Was just wanting to see how easy it would be to put back to standard at some point in the future. But also keeping it able to swap back to MAME.
Nick
obcd
3,830CR
You could connect the buttons and joysticks in parallel to the IPAC2 and the JVS interface if both interfaces are switching 5V to GND. If you don't have a JVS interface, there is an open source project using a Teensy 3.1 to create a JVS interface. The Teensy uses a 32 bit arm processor, so I don't think a normal arduino could do the job as well. It will likely cause delays. It all depends how good your soldering and software skills are.
AndyGeezer
599CR
Jvspac is a jvs keyboard encoder that works in mame.
You can then keep everything as is.
AndyGeezer2015-10-21 09:19:32
simonden
20 (100%)
1,042CR
I think Andy means a JVS-PAC
A JVS-PAC is the equivalent of an IPac/JPac for when you have a JVS I/O board installed in the cab. Makes it much easier to swap between PC and NAOMI.
tazfaedodge
91CR
Sorry if I'm being stupid here but just not getting it.
I don't have a Naomi I/O board all buttons and sticks are wired into an IPAC2, and from what I can see from what a JVS-PAC is, is that it plugs in after the Naomi I/O board and converts those inputs into keyboard keys of a PC letting you play MAME games on your PC.
So would it be easier to have a second loom connected to the buttons/joys with a JAMMA or other type connector on it?
Ether that or can someone come round and kick this thing till it will take a Naomi Emulator and run the F*****g games.
Nick
obcd
3,830CR
They assumed you had an original sega naomi JVS board for your cabinet. In such case, the JVS-PAC is indeed the easiest solution. JVS IO boards often show up on ebay.
