Has anyone successfully used a Naomi DIMM board that has been upgraded to Firmware version 1.02 to 4.02 and used a Net DIMM daughter board on it instead of the GD ROM daughter board?
I took a gamble on some untested Naomi Net DIMM boards that appeared to have broken connectors. I believed they could be untested because of the connectors, which at least one on each were mashed. I manged to properly replace the connectors but there was a lot more going on beyond the connectors - they looked like they had been thrown around too (component knocked off, etc). All the boards were bad. However, I managed to fix both the top ethernet boards which had some fairly simple damage/dry joints.
I have been told that the main DIMM boards and Net DIMM boards are identical and interchangeable by someone who upgrades 1.02 DIMMs to 4.02 but I can't get an upgraded 4.02 DIMM board to work with a Net DIMM top board. Anyone had any luck? I don't think it's me. It would be better if I could use the 4.02 DIMM boards with Net DIMM boards but it isn't happening for me. I have plenty to test with - so it's not the voltages, Naomi motherboards, the bios chip, or the DIMM boards. It's that specific combination that isn't working.
