will try to remove replace the naomi rams for first time
i have some spare naomi pcb so going to practice
just wonderd if anyone has any good advice
i will use solder removal ribbon and a flat tip on solder iron…
i do have a hot air station also but worried i will fry the ram chip with this hot air
looking for advise on the replacement also of the ram…
like i have seen that soldering just the first and last legs then fill in the rest with a wipe of the flat tip plus flux
any help massively apretiated
10 naomi’s in hand needing rams would be good to have some of them working againRetroman8392021-10-09 13:31:33
