NAOMI input issue
big10p
Coins detected in pocket!
6,087CR
Continuing on my journey to get my NAOMI cab fully operational, I have discovered another issue - a button appears to be 'stuck on' (despite that button not actually being wired up!).
If you look at the input test pic below, you can see there's an input reading as 1 (pressed) in the player 1 inputs. Thing is, I don't know what button (or possibly joystick?) input that relates to. Does anybody know? Is this likely to be a faulty IO board?
Thanks.
Shun
500CR
It could be an issue with the io board, or a wire could be shorted somewhere. I'm trying to figure out off the top of my head which button/joystick input that is. It could possibly be P1 start as there are 6 inputs to the left of it which could be P1 1-6 buttons.
If you don't get an answer by the time I get home tonight, I'll fire up my Sega Naomi and check.
2,265CR
remove the input connector on the I/o board, go back in to test mode using the buttons on the motherboard and see if it still shows as on. If it doesn't check your ground wiring continuity, if it's struck on with nothing hooked up swap the i/o board.
big10p
6,087CR
Cheers Shun, that would be useful. I can't even check by process of elimination as this cab uses analogue controls almost exclusively (pool game). Just so happens (sod's law!) the 'stuck' input means I can't play the game.
Cheers Olly - of course! I did think about unplugging the input connector to check, then realized I wouldn't be able to get into the test menu. Completely forgot about the test/service buttons on the filter board.
I really hope the IO board isn't busted...
big10p
6,087CR
Had a bit of time to look at this again, so unplugged the IO board input, and tested again. All inputs now show as 0 so relived its not a faulty IO board, but a short somewhere...
So, now started looking at the wiring, and noticed this!
The blue wire I'm holding with my finger is connected to P1 button 1. For some reason I really can't imagine, there's a white loop-back wire to ground, on the connector.
No wonder that input was showing as 'pressed', then!
Of course, unplugging the loop-back sorted the issue. This is in a dedicated Shootout Pool Prize cab that only uses the P1 start button, so why this 'mod' was done completely baffles me. Any ideas?
