Naomi Netboot reset relay
chunksin
21 (100%)
733CR
I'm ordering some parts to build a reset relay for the Naomi/Naomi2 to allow hard reset of the Naomi unit when it gets stuck on certain roms. The issue affects a few Naomi games plus all of the Atomiswave titles and there is a solution over on arcade-projects.com that resolves it.
They are grounding the tach pin on the internal fans of the Naomi which seems slightly over-engineered to me, I'm planning on building an external plug through power connector that will interrupt the main 12v supply to the Naomi momentarily using a relay via a signal from the Pi GPIO activated by a script run from the web interface and it will only do that on games with known issues, the code will be included in my Wifi netbooter image which works on a Pi3.
I'm ordering parts to make 10 kits, 2 are taken so there are 8 up for grabs, let me know if you're interested, they'll come in between 5 and 10 quid posted.
