Naomi Pad hack Help
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
I did a pad hack on a DC controller to use it on the Naomi
I wired the it to the correct pins
when I turn on the Naomi the VMU makes that ping noise it does when in a DC console but then that's it
I don't get anything more than that
is there a setting or something I have to enable to get it to work
I tried it with games that are supposed to work but get nothing
any help would be great
grobda
1,061CR
on my naomi 2 theres two buttons on the panel all the connectors are on labelled psw1 and psw 2. psw1 gets you into test mode then its psw2 to select and ps1 to enter.
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
Thanks I knew about the buttons what I couldn't find was the menu for it
but since I have realised what the problem is
I tried on an Emulator to see and basically these pad hacks only work on Japanese Bios
mine is Export so I need to change that and the option will show up within the actual game test menu
