Naomi sound problem
bonehead
I'll get pix tonight
50 (100%)
1,729CR
I have a Naomi 18 wheeler with a sound problem.
I get bass through the bass speaker by no treble or speech through the front speakers.
In test mode it says left and right speakers off. I select them to on but as soon as you go out of test mode they say off.
Any idea what's wrong or how to solve it please?
Thanks,
Steve
Outrun2
Colonel Outrun
1,181CR
The test mode thing just outputs a continual beeeeeep so you can test each speaker (left or right) independently. When you set one to ON you'll hear the beep out of the speaker side selected.
As they're both not working you might have a problem with the sound amp, but check for loose connectors on it first before trying to source a replacement.
Also, can you try a different cart to make sure the problem isn't game related?
bonehead
50 (100%)
1,729CR
Thanks for the reply, I here the beep from each speaker it just doesn't hold the settings. Each time you come ou of test mode it just goes back to speakers off.
I will try my crazy taxi cart in it.
Cheers,
Steve
griffo83x
30 (100%)
745CR
try replacing the phono leads first , i replaced the sound amp in my naomi only to find it was the leads at fault , sounds like you amp though maybe if your getting the beap, i was not getting any sound from 1 speaker
i do have a spare amp i can sell you though if you need one
griffo83x2014-12-10 13:38:21
