NBA Jam sync
Lastspaceship
205CR
Got a nice looking NBA Jam board (rev 3.01 I think not TE), seems to be an issue (I think) with vertical sync - board boots fine, sound works fine (with sound board) but image is scrolling vertically. Tried on my New Astro City as well as a couple of of CRTS (one Sony, one little brionvega), all the same. Board boots fine, seems to be running fine (from what I can see). Tried pressing chips and components a bit, havent reseated any yet. Did try the adjustments on the NAC monitor control board too. I read this is common with these midway boards. Worked I believe with previous owner on a sigma supergun going into an LCD.
Anyone had this? fixed it? Wondering about next steps or whether its just not playing well with my combo of monitors..
Sbdesign
SEGA collector
1,721CR
The sync does seem slightly different to most.
I have all the NBA jam boards and have seen this issue but for me I managed to tune with sync pot.
Even on my pi2jamma, and pc build, I get scrolling on these games prior to adjustment. if i remember right, once I get the adjustment just right it can work with other games on the same sync position.
Lastspaceship
205CR
Ah thanks. I tried back in the the new Astro which is ms9 - the remote board does vertical adjustment but not sync - not even sure if there is a pot on the monitor to do that. No adjustment I don’t think on the crts I have so might be a dead end unless I’m being thick (likely)
5,325CR
I'd get an oscilloscope on the sync signal. It could be weak/damaged, so not high enough for the TTL-sync levels of arcade monitors. I dunno about NBA Jam, but sometimes the devices producing the sync output aren't massively protected, or capable of much 'oomph'.
neoretro
1,121CR
The Sega swing has all its adjustments at the front of the cab when you lift the monitor frame.
Don’t know if it’s the chassis or a remote board, but if that’s not how you’re looks it probably isn’t the original monitor
Lastspaceship
205CR
Yeah it’s original but ms9 in a new Astro which has a remote board near the cp. Will see if there’s a vhold. Love the swing such a cool machine just seen one in person.
Sbdesign
SEGA collector
1,721CR
I believe its on the side of the monitor, real chew, just plan a day to have monitor setup on a bench next to cab. or remove chassis and tweak a little and out it back.
Think it has 2 pots, one for 15khz, the other 24khz
Lastspaceship
205CR
Ah thanks for info appreciated. sounds like a bit of work to be swapping in and out games, but want to see if I can get it under control.
