Need Help on two machines!!! :-(
ltearle
57CR
So tomorrow I am getting four machines tomorrow and I thought I'd play some of my machines, got a Neo Geo a while back never tried it, turn it on, nothing happens but a strange click. So I turn it on look behind and there's a little spark, looks like something has snapped. Heres a picture where you can clearly see tge area, can this be fixed?
My duel moniter playchoices bottom moniter has started to Flickr, where do I start to fix that?
Please help me!!!
IDCHAPPY
KANFU Master
9 (100%)
1,523CR
Is there not pots on the chassis of the bottom playchoice monitor that you can fiddle about with? it looks like the vertical hold may be off? is it a rolling image?
ltearle
57CR
Alpha1 said:
if its a rolling image on the playchoice then adjust the vertical hold.
Ok I will have a look, it wasn't rolling the last time I played? Can it just happen?
JESSYBR said:
hi thats look like the high voltage transformer is gone if you can find one its repairable
look out with the high voltage
gr robert
Ok, so it's fixable. Any tutorials or threads anyone could recommend so I have something to follow?
RaveN
1,325CR
JESSYBR is right. If there's a crack in the LOPT and you see sparks coming from it, then it's time to get a new one. Easily repairable assuming you can find a new LOPT.
