Negative Voltage ATX PSUs
ShinraArcade
17 (100%)
19CR
Does any one know of any preferably cheap ATX PSUs which have -5v?
I've got quite a few ATX supplies floating around but none of them seem to have the -5v.
If there's a list somewhere that would be great.
ShinraArcade
17 (100%)
19CR
Thanks, I think your right in that it's no longer standard for 24pin atx 2.0 but some older supplies (20 pin) definitely had a -5 on pin 18. With that I think I may have answered my own question partly.. I'll try and search for ATX 1.0 supplies.
But if anyone knows of any please let me know.
Fantazia2
2,246CR
The earlier AT power supplies have -5v as its required for the ISA bus I think.
Is it not possible to build some sort of circuit to do something on the -12v line to give -5v?
5,332CR
7905 voltage regulator will get you -5V from -12V, but only up to 1A (with a heat sink). Might be enough if all -5V does is feed op-amps.
A isolated DC/DC converter off the 5 or 12V would be slicker (That’s all those ‘negatron’ (
) things are on eBay).
ShinraArcade
17 (100%)
19CR
Del Griffith said:
Enlight hpc 250 (lots on ebay)
Up sides....
-5v
20 pin connector
Rocker switch
Quiet fan
Downsides....
Pretty old now
Thanks Del. That's amazing exactly the response I was hoping for, they're dirt cheap as well. Just bought one for less than a tenner on eBay.
Thanks John for the info re converting, would like to give this a try at some point since I have a few supplies to hand.
ShinraArcade
17 (100%)
19CR
simonden said:
Some superguns now have -5v built into them, so no need to worry about finding AT (or ATX 1.0) PSUs.
Ah that's good to know, (apparently obvious) but that's exactly why I needed the -5v. I've got a couple of Vogateks from 2008 so I'll still need the -5v for now.
Could you direct me to any of the cards/info with the integrated negative voltage?
ShinraArcade
17 (100%)
19CR
simonden said:
http://retroelectronik.com/en/supergun/145-supergun-progamer-arcade-jamma-autofirevoltmeter-included-5674864654514.html
Cost a bit more than my Vogateks think I got two for less than £20 from different sellers. Some nice features has to be worth paying the extra.. Don't need one right now but is there a UK reseller for this?[sub][/sub][sup][/sup]
