Nemesis pcb.
thechop
Model 3 Man
15 (94%)
388CR
Received this today and have a few questions if anyone's experienced these boards, it's the first I've owned.
Nemesis board won't boot at all in 3 of my cabs a minicute,awsd and an egret 2 I'm assuming it's something ground related as it's the same in all 3.
Naomi upright with a Franco B loom boots up fine, sound fine, stick works fine can fly about lovely, just none of the three buttons work.
Go into test menu and buttons 1 and 2 show working on and off as buttons pressed button 3 nothing, back into game and no buttons work but sticks do.
Please someone tell me I'm not going mad lol
Using this adaptor
http://www.ukvac.com/forum/konami-to-jamma-adaptorfound_topic351341.htmlthechop2016-04-27 22:12:56
Equites
Chief Sheesher®
35 (100%)
3,329CR
Using this adaptor
Non working inputs are common on these, likely a failed Opto IC or two.
thechop
Model 3 Man
15 (94%)
388CR
Using this adaptor
Yeah thanks, think it won't boot in the other cabs because all 4 5v inputs aren't wired on older egret 2 cabs guessing the awsd may be the same but will have to check tomorrow hoping those inputs are fed by a 5v that's not connected(C/D) but it's strange they work in test mode (well 2 do) and not in game that's for sure.
thechop
Model 3 Man
15 (94%)
388CR
Equites said:
Missile and Special Weapons buttons will not work until you get a powerup during game.
So in theory they could be the ones working in test but as I can't shoot anything to get a power up I don't know yet ?
So may only be missing standard shot, defo 1 and 2 working in test mode tho, 3 non.
Equites
Chief Sheesher®
35 (100%)
3,329CR
I repaired a Nemesis with input problems last week for Alpha1. The Fire and Missiles were stuck on.
Button 3 is Fire, Button 2 is Missile, Button 1 is Special Weapons.
thechop
Model 3 Man
15 (94%)
388CR
Yeah its 1 and. 2 show as working so it's the shoot button I'm missing , hoping its powered on a 5v my cab isn't wired for as I'm sure these old boards need all four 5v fully wired egret 2 only has 3 on the harness wired.thechop2016-04-28 06:36:36
5,653CR
I think losing a button on Nemesis is fairly common. The ICs controlling inputs fail.
Had just fixed the exact same fault on mine!
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
I sent you a pm MR Chop
when designing those adaptors i realsied that Button 3 and Gyruss Stereo Points would clash so i made a provision on the adaptor to allow for the user to choose what the wanted via Solder points
i completely forgot about this because your the first to ask for a Nemisis version of the adaptor
its very odd that Nemisis uses button 3 as its fire but that may just be your issue because button 3 need a fly lead soldered
Blue is for Player 1 and Green is for Player 2
this will fix your issue i believe (so no optos are dead)
this thread relived my memory of when i built the adaptor so thanks communitiy
thechop
Model 3 Man
15 (94%)
388CR
H there Mr Fox, you are indeed right, I soldered a wire where you said(well on the Jamma edge as those little holes are far too fiddly for my ham-fists) and alls well.
Only thing now is to solve why it doesn't like my other cabs, I've read it's because there is no +5v on the Jamma harness at D and combining C and D might do it but just wondered if your adaptor would like that or if extra wires to take the extra load strain would be needed.
vib_ribbon
488CR
i have a mate who had a similar problem with bubble bobble for the longest of time. in the end, he soldered pins 4+D together and then everything worked! he had the board for like 4 years before this point and he had sent it to me (it worked all my supergun and both my egret 2s), but just not on his cab.
thechop
Model 3 Man
15 (94%)
388CR
Yeah three cabs it won't boot in, the one it will isn't mine anymore as its sold lol so won't be here much longer.
I'm petrified to try anything with the +5 in case I f**k something up. Defo 4 and D ? I read somewhere C and D but haven't investigated any further.
vib_ribbon
488CR
i only use jammaboard connectors (god bless tim's soul), 3+4 are already connected, and C+D are too.
i guess you can always try doing that first...? but i'm sure he told me he connected 4+D together which solved his particular problem.
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
just to clarify
my adaptor has
pin 1, 2 27, 28, A, B, e, f connected to GND
pin 3, 4, C, D connected to +5
pin 5, E connected to -5
pin 6, F connected to +12
weather the actual cab sends out those voltages on those pins is another matter
grobda
1,061CR
you checked your +5v levels? might need adjusting. all the 5v pins on silverfoxes adaptor look like they're wired together so pins shouldn't matter.
It doesn't need -5v.
Mr Halibut
29CR
My Nemesis is pretty temperamental on the E2. It often boots to a black screen, then after I reseat the Jamma connector or Konami adaptor or something a couple of times it will work fine, but then the next day may do it again. I'm not sure if reseating the connectors does anything or if it's just taking time to 'warm up' in some way.
Also it's very sensitive to 5v, I've had it boot to black screen (at around 5.0-5.1v at the jamma connector) and turning up the 5v just a tiny bit had it suddenly spring to life.
thechop
Model 3 Man
15 (94%)
388CR
grobda said:
<span style="line-height: 1.4;">you checked your +5v levels? might need adjusting. all the 5v pins on silverfoxes adaptor look like they're wired together so pins shouldn't matter.</span>
</span>
<span style="line-height: 1.4;">It doesn't need -5v.</span>
</span>
I do run my cabs as low is I can tbh prob 5ish without a board drawing power, and normally have no probs, I did lift it to 5.25 but it made no difference although I haven't checked what this draws I know the Naomi gives out a bit more as its using the JVS sun psu.
I think it's the D 5v but if they're all connected on the adaptor it should work ok I'm guessing as its getting all 4 eventually also all the GND's aren't connected together either wondering if that may be something to do with it too.
