New arcade cab owner needing technical help
RetroDave Nintendo
20CR
Hi everyone. I'm new to the arcade scene after having purchasing my 1st cab in August. Now it's broken and I need some help if possible please.
I bought an Operation Wolf cab back in August which worked but needed some tinkering. The screen needed colours adjusting and centering etc which I managed to research and do myself with the help of an online manual for the monitor / chassis fitted. I had a problem with the screen momentarily blinking on and off very quickly and the image zooming in and out from the edges of the screen. After some more reading it turned out the be lower than required voltage to the monitor. I think it was 108v instead of the 126v recommended in the manual I was referring too. I adjusted the voltage to a shave under the 126v using the adjustment on the chassis (RV12 I think) and the screen issues were immediately resolved. A quick re-adjustment of the brightness and colours and it has been working without issue since...until now.
I noticed the last few times I've turned the machine on over the last week that sometimes the image is darker than normal...after turning the game off and then waiting a moment before trying again it would then start up and the picture would be back to normal again and play without issue. I've noticed this happen 3/4 times in the last week making we wonder if something is on its way out. Well as of Monday the screen is now totally dead...as in no picture at all. It turned on at first as normal and looked fine. I turned my back to make a drink and came back to find no picture but the game was running blind with sound as normal but just no image.
Confused, I turned it off and back on again but still no picture. Tried again the next morning and still dead.
I've taken the back door off to have a look for anything obvious but can't see anything untoward. I turned the machine on and there isn't the usual static sound from the monitor upon start up or shut down so it's like its not getting any power at all but I can't be sure....
I left it for about 20 seconds and then could hear a ticking noise from the chassis area...I panicked and turned it off and left it for the night.
I then had a go at checking the fuses that I could see with a multimeter today and they are ok. I then checked the voltage at the flyback transformer as soon as I turned the power switch on and it read 186v !! So very quickly turned it off again incase it blows something....
Does this sound like a flyback transformer that's been on its way out and that has now packed up or something else?
Would it just need a new cap kit?
I have no clue as I am not electronically minded and have never messed with this kind of thing before. All I know is what I've read online from old threads and the original chassis monitor manual online.
I can tell you that its a Hantarex MTC900 chassis running a 19" Videocolour monitor. The chassis has code Hantarex DF04 printed on it behind the adjusting dials.
Any help and advice would be greatly appreciated.
Cheers. Dave
big10p
Coins detected in pocket!
6,093CR
Hi Dave. Welcome!
I'm having monitor woes myself ATM, too. I believe a ticking sound is indicative of a bad lopt/flyback. Post in the tech/maintenance section and somebody (probably gunblade
) will be able to point you in the right direction.
Joker CK
74CR
Could be the flyback but i would check the voltage regulator IC in the B+ voltage section. If this is shorted then your voltage will be too high going to the rest of the chassis and could start blowing out other components. I bought a cab with a dead Wells Gardner K7000 that had blown fuses and capacitors which turned out to be the voltage regulator. Replaced it and the parts it had blown out and it has been fine ever since. Worth checking it just in case. Hope you get it sorted.
RetroDave Nintendo
20CR
Hi!
Thanks for taking the time to comment :)
Yeah I will probably post in that section soon.
Nightmare isn't it when things don't work!
I hope you get your monitor issues sorted soon too.
RetroDave Nintendo
20CR
Cheers! Thanks for the comment/advice :)
Problem is i don't really have a clue what I'm looking at and how to fix it....
I'm going to have to try and find someone that's willing to help fix it for me as I'm no good with electronics.
Thanks again
