New screen or replace bulb
si07
11CR
Hi guys i have purchased a HOTD 4 Delux. it has a LG 52inch DLP .the screen is a little dull ??is there any alternative flat screen that would fit ? and would work just as good. or would it be easier to replace the bulb in the tv thanks all
obcd
3,830CR
Are you sure there is just one bulb? Doesn't those large projection screens use 3 picture tubes to project the picture? (At least that how it worked in a house of the dead III)
Have you checked those tubes and removed any dust that might be on them? They are placed facing up, so they easily collect dust. Obvious, if they had long working hours, the tubes could be on their way out. Those projection screens never where very sharp from the beginning, but maybe HOTD4 uses a different technology?
si07
11CR
Hi
I have hooked the monitor up to another console it works fine but the picture isnt very good .. colour looks dull ... brightness is the same.. so i was looking to replace with a LCD if they work with HOTD4 ?? i might just get a new bulb and see if that brightent the picture up they are quite cheap
tb2000
3,578CR
These cabs use a 16:9 DLP rear projection TV, the LG 52SZ8R, so it just uses one UHP lamp. They use the VGA input, and with a new lamp they have a really quite impressive image quality.
